ranton utente attivo
Iscritto: 27 Set 2005 Messaggi: 5333
Inviato: Gio 31 Ago, 2017 11:46 am Oggetto: |
Annunciata ufficialmente.
Citazione: | Here are some highlights of the E-M10 Mark III’s specifications:
- Same 16MP image sensor, but with updated processor Truepic 8, the same processor used in E-M1 Mark II
- 5-Axis Image Stabilization, with slight improvements
- UHD 4K video capture (3820 x 2160 resolution)
- 121 AF points from E-M1 Mark II, instead of 81 points from E-M10 Mark II
- New Cluster AF points selection, similar to E-M1 Mark II, but limited to only S-AF, and does not work in C-AF mode
- Autofocus is contrast detect only, hence no improvement in C-AF tracking mode
- Same built in EVF and Touch-AF LCD screen as the older E-M10 Mark II
- Slightly reworked and simplified menu and shortcuts
- Improved design of the hand-grip. |
Citazione: | Olympus should update their image sensor to the new 20MP one, instead of using the 16MP image sensor from their older cameras. I do not see much or any improvement in terms of image quality over the E-M10 Mark II. I am disappointed with the omission of wireless TTL flash support in the camera, and no availability of external grip attachment. The reworked menu and shortcuts could have been better improved. | https://blog.mingthein.com/2017/08/31/review-2017-olympus-e-m10-mark-iii/ _________________ Le foto su Flickr. I video su YouTube. Non sono niente di che.
Olympus E-M1 II, 12-45mm f/4 PRO, 75-300mm f/4.8-6.7 II, 60mm f/2.8 Macro, Panasonic 9mm f/1.7. Flash Godox V350. |
