inattinico utente
Iscritto: 17 Gen 2009 Messaggi: 142 Località: Roma
Inviato: Mar 03 Mar, 2009 6:42 pm Oggetto: [Roma] Zenit 122S Fotosniper+Zenit TE+obiettivi vari |
Zenit fotosniper :
- Zenit 122s;
- ob. 300 mm f/4.5, 3 filtri colorati + UV;
- ob. 58 mm f/2
- "fucile" fotografico con cinghia e calcio per spalla;
- paraluce;
Zenit ET
- ob. 50 mm f/2
- ob. Helios 85 mm f/1.5
- 1 teleob. catadiottrico MC RUBINAR 10/1000 MAKPO completo di 3 filtri colorati (Arancio-verde-UV), paraluce e borsa in pelle;
- borsa pronto;
Tutto in OTTIME condizioni, funzionanti e revisionati da 6 mesi.
In blocco a € 600 tratt.
Si valutano permute.
Descrizione prodotto (in inglese)
Fotosniper is designed for taking close-up pictures of distant objects, animals, birds and plants under natural conditions. It can be successfully used for sports photography as well as for taking pictures of architectural designs etc. The versatile FotoSniper FS-12 takes the complexity out of telephotography.
A rifle-type support, comfortable shoulder brace, and contoured pistol grip allow smooth, steady framing of subjects in motion. The TAIR 300mm f/4.5 lens lets you shoot as near as ten feet (3m)...and, for instant response, both the depth-of-field preview and shutter release operate from the single FS-12 trigger. Other features include a split-image rangefinder. fingertip focus control, TTL exposure metering. and shutter speeds to 1/500th of a second.
As a system, the Fotosniper is a combination of ZENIT 122S semi-automatic reflex camera with an MC TAIR 300mm f/4.5 telephoto lens mounted on a release mechanism. The lens can also be used for macrophotography, microphotography or copying.
A semi-automatic exposure meter operates through the lens (TTL system) providing correct exposure with the standard lens as well as with interchangeable lenses, light filters, supplementary lenses, or extension tubes. LED metering in the viewfinder indicates the correct exposure setting, which can be seen both with the diaphragm fully open or stopped down. Instant mirror return ensures continuous viewing of a subject before and after exposure. Shutter speeds range from 1/30 sec to 1/500 sec with B, and distance scales from .5m to infinity. Power is supplied by two 1.5 volt batteries (Maxell LR 44). Weight, in operating state, is 3.0 kg and in case 5.8kg.
Five filters are included in this set: UV-1 (colorless filter which eliminates the influence of ultraviolet rays in black-and-white and especially in color photography), O-2.8 (Orange filter used fro black-and-white photography for taking pictures of remote objects to eliminate the effect of atmospheric haze and provides contrast for images. With this filter, the sky is reproduced very dark and the clouds are bold and bright), Y-1.4 (a light yellow filter which improves color rendition of blue, green and yellow objects in portraiture under natural illumination), Y-2 (a yellow filter widely used in landscape photography and emphasizes clouds while increasing contrast of shadows and remote objects; it also eliminates effect of atmospheric haze), and YG-2 (this yellow/green filter is of special value for color-correct rendition; particularly red and green colors). Thread size is 72mm x 0.75. (Fonte: http://www.kievusa.com/fotosniper.html)
A seguire allegherò qualche foto
Inserito anche altrove.
Ultima modifica effettuata da inattinico il Gio 05 Mar, 2009 8:08 pm, modificato 1 volta in totale |
inattinico utente
Inviato: Mar 03 Mar, 2009 7:47 pm Oggetto: Foto. |
PDv utente
Iscritto: 11 Ago 2005 Messaggi: 113 Località: Terlizzi (BA) / Nijmegen (NL)
Inviato: Mar 03 Mar, 2009 9:45 pm Oggetto: |
ciao, hai intenzione di smembrare? in tal caso quanto chiedi per l'helios 85?
Paolo |
Piero_Bo utente attivo
Inviato: Mer 04 Mar, 2009 9:48 pm Oggetto: |
inattinico, le prossime volte edita il messaggio iniziale cliccando su alla destra dello stesso invece di rispondere
Ti consiglio anche di dare un lettura al regolamento in quanto sei nuovo del forum, grazie _________________
1DMk2n in vendita .... |
sambo nuovo utente
Iscritto: 10 Giu 2008 Messaggi: 13 Località: roma
Inviato: Gio 05 Mar, 2009 8:31 am Oggetto: |
coda per l'helios 85-1.5 se scorpori
fammi sapere eventualmente il prezzo, se valuti cambi fammi sapere che
cosa ti interessa!
SAMBO |
sambo nuovo utente
Inviato: Gio 05 Mar, 2009 8:34 am Oggetto: |
dimenticavo : nel caso andasse in porto la vendita , consegna a mano a roma!
SAMBO |
inattinico utente
Inviato: Gio 05 Mar, 2009 8:07 pm Oggetto: |
Ciao a tutti.
Al momento cerco di dare via tutto in blocco.
Se dovessi ripiegare su eventuale smembramento, vi terrò presente così come da coda.
@Piero_Bo:
Chiedo venia, ho dimenticato di editare. C'è modo di riparare rimettendo tutto nel primo post?
Ho letto tutto il regolamento e successive modifiche prima dell'apertura del topic.
Grazie per i tempestivi ragguagli.
Saluti. |
Inviato: Gio 05 Mar, 2009 8:14 pm Oggetto: |
| inattinico ha scritto: |
@Piero_Bo:
Saluti. |
Lasciamo cosi .. _________________
inattinico utente
Inviato: Dom 08 Mar, 2009 3:35 pm Oggetto: |
| Up |
inattinico utente
Inviato: Gio 12 Mar, 2009 9:21 pm Oggetto: |
| yUPping |
inattinico utente
Inviato: Sab 21 Mar, 2009 5:24 pm Oggetto: |
| up |
inattinico utente
Inviato: Lun 30 Mar, 2009 3:37 pm Oggetto: |
Su!  |
radius utente
Iscritto: 09 Ott 2008 Messaggi: 363 Località: VIBO VALENTIA
Inviato: Sab 23 Mgg, 2009 8:16 pm Oggetto: |
| coda |
inattinico utente
Inviato: Mar 13 Ott, 2009 10:14 pm Oggetto: |
| riuppete |
Paolo81 utente
Iscritto: 26 Gen 2009 Messaggi: 85
Inviato: Mar 05 Gen, 2010 6:44 pm Oggetto: |
| CODA per il Rubinar se smembri |
radius utente
Inviato: Ven 15 Gen, 2010 10:45 pm Oggetto: |
| Coda per helios |
radius utente
PDv utente
Inviato: Dom 15 Ago, 2010 10:21 am Oggetto: |
Ciao, è ancora tutto disponibile? Ricordo che se smembri sono ancora in coda per l'Helios, fammi sapere.
A presto e grazie
Paolo |
