coccinella
Andrea Artoni
Iscritto: 26 Mar 2004
MessaggioInviato: Sab 30 Apr, 2005 8:52 pm    Oggetto: coccinella Rispondi con citazione
Oggi guardavo le rose nel giardino e mi sono accorto che le foglie erano colme di questi graziosi insetti.
Ho montato le lenti close-up sulla mia fuji s5000 ed ho scattato a mano libera.
Per i cultori dei numeri accludo i dati exif.
File: - D:\FOTO ORIGINALI\300405\DSCF1300.JPG
Make - FUJIFILM
Model - FinePix S5000
Orientation - Top left
XResolution - 72
YResolution - 72
ResolutionUnit - Inch
Software - Digital Camera FinePix S5000 Ver3.00
DateTime - 2005:04:30 12:00:40
YCbCrPositioning - Co-Sited
Copyright -
ExifOffset - 252
ExposureTime - 1/90 seconds
FNumber - 8.00
ExposureProgram - Aperture priority
ISOSpeedRatings - 200
ExifVersion - 0220
DateTimeOriginal - 2005:04:30 12:00:40
DateTimeDigitized - 2005:04:30 12:00:40
ComponentsConfiguration - YCbCr
CompressedBitsPerPixel - 2.00 (bits/pixel)
ShutterSpeedValue - 1/91 seconds
ApertureValue - F 8.00
BrightnessValue - 6.42
ExposureBiasValue - 0.00
MaxApertureValue - F 2.83
MeteringMode - Spot
LightSource - Auto
Flash - Not fired, compulsory flash mode
FocalLength - 57.00 mm
FlashPixVersion - 0100
ColorSpace - sRGB
ExifImageWidth - 2048
ExifImageHeight - 1536
InteroperabilityOffset - 1104
FocalPlaneXResolution - 3827
FocalPlaneYResolution - 3827
FocalPlaneResolutionUnit - Centimeter
SensingMethod - One-chip color area sensor
FileSource - DSC - Digital still camera
SceneType - A directly photographed image
CustomRendered - Normal process
ExposureMode - Auto
WhiteBalance - Manual
SceneCaptureType - Standard
Sharpness - Normal
SubjectDistanceRange - Unknown
Maker Note (Vendor): -
Version - 30333130
Quality - NORMAL
Sharpness - Normal
White Balance - Auto
Color saturation - Normal
Flash Mode - Off
Flash Strength - -0.30
Macro - On
Focus mode - Auto
Slow Sync. - Off
Picture Mode - Aperture prior AE
Unknown - 1
Sequence mode - Off
Unknown - 0
Blur warning - No
Focus warning - No (Focus OK)
AE warning - No (AE good)
Andrea
 Dimensione:  88.62 KB
 Visualizzato:  File visto o scaricato 428 volta(e)
silvershadow
Iscritto: 17 Mar 2005
MessaggioInviato: Sab 30 Apr, 2005 8:55 pm    Oggetto: Rispondi con citazione
Avrei usato se possibile una focale maggiore...
A quanto si ferma la Fuji? 8 è il massimo che la macchina ti concede? (scusa ma non conosco molto la S5000)
Andrea Artoni
MessaggioInviato: Sab 30 Apr, 2005 8:59 pm    Oggetto: Rispondi con citazione
Se per focale intendi diaframma allora la s5000 arriva massimo a f9.
Però il tempo di esposizione si sarebbe ulteriormente abbassato con il rischio di micromosso.
Andrea
diavoletto
Iscritto: 05 Mar 2004
MessaggioInviato: Sab 30 Apr, 2005 9:09 pm    Oggetto: Rispondi con citazione
La foto è poco nitida....non riesco a capire se sia un problema di micromosso o di fuoco incerto!
Andrea Artoni
MessaggioInviato: Sab 30 Apr, 2005 9:12 pm    Oggetto: Rispondi con citazione
Tutti e due!!!
ho scattato a mano libera e con tempo 1/90.
Andrea
diavoletto
MessaggioInviato: Sab 30 Apr, 2005 9:17 pm    Oggetto: Rispondi con citazione
a mano libera con 1/90 con la S5000 con una coccinella ferma........non ci dovrebbe essere mosso, a meno che non ci fosse stato vento!
Andrea Artoni
MessaggioInviato: Sab 30 Apr, 2005 9:23 pm    Oggetto: Rispondi con citazione
Bingo!!!
Inoltre con tre close-up montate e con lo zoom alla massima estensione...
Andrea
diavoletto
MessaggioInviato: Sab 30 Apr, 2005 9:29 pm    Oggetto: Rispondi con citazione
così almeno sai cosa non fare la prossima volta Wink
