Piccolo fiore
nuvoletta
Iscritto: 05 Apr 2004
MessaggioInviato: Mer 13 Apr, 2005 11:18 am    Oggetto: Piccolo fiore Rispondi con citazione
Ho provato ad utilizzare le lenti macro +10 per realizzare la foto di questo fiore (la cui grandezza reale è di 5mm), ma la messa a fuoco non mi riesce..... Crying or Very sad Crying or Very sad Crying or Very sad
Dati EXIF:
Make - Canon
Model - Canon EOS 300D DIGITAL
Orientation - Top left
XResolution - 300
YResolution - 300
ResolutionUnit - Inch
DateTime - 2005:04:07 16:50:21
YCbCrPositioning - Centered
ExifOffset - 196
ExposureTime - 1/400 seconds
FNumber - 2.80
ISOSpeedRatings - 100
ExifVersion - 220
DateTimeOriginal - 2005:04:07 16:50:21
DateTimeDigitized - 2005:04:07 16:50:21
ComponentsConfiguration - YCbCr
CompressedBitsPerPixel - 3 (bits/pixel)
ShutterSpeedValue - 1/400 seconds
ApertureValue - F 2.80
ExposureBiasValue - 0.00
MaxApertureValue - F 2.80
MeteringMode - Multi-segment
Flash - Not fired
FocalLength - 105 mm
UserComment -
FlashPixVersion - 100
ColorSpace - sRGB
ExifImageWidth - 1240
ExifImageHeight - 1003
InteroperabilityOffset - 2366
FocalPlaneXResolution - 3443.95
FocalPlaneYResolution - 3442.02
FocalPlaneResolutionUnit - Inch
SensingMethod - One-chip color area sensor
FileSource - DSC - Digital still camera
CustomRendered - Normal process
ExposureMode - Auto
WhiteBalance - Auto
SceneCaptureType - Standard
Maker Note (Vendor): -
Macro mode - Off
Self timer - Off
Quality - Fine
Flash mode - Not fired
Sequence mode - Single or Timer
Focus mode - AI Focus
Image size - Large
Easy shooting mode - Manual
Digital zoom - None
Contrast - High , +1
Saturation - High , +1
Sharpness - High , +1
ISO Value - 100
Metering mode - Evaluative
Focus type - Auto
AF point selected -
Exposure mode - Av-priority
Focal length - 105 - 105 mm
Flash activity - Not fired
Sequence number - 0
White Balance - Auto
Image Type - IMG:EOS 300D DIGITAL JPEG
 Dimensione:  71.67 KB
 Visualizzato:  File visto o scaricato 762 volta(e)
: - il mio album - : * * *___ In suo ricordo ogni mio scatto canterà la vita ___* * *
Canon EOS 300D + Canon EOS EF S 18-55mm f/3,5 5,6 + Sigma 75-300 F4-5,6 APO Macro Super II DG + Sigma 105mm F.2.8 EX DG macro + Sigma EF-500 DG ST
Grazie a tutti per ciò che avete fatto!!!
Redmondbarry
Iscritto: 11 Dic 2004
MessaggioInviato: Mer 13 Apr, 2005 11:28 am    Oggetto: Rispondi con citazione
Io di macro sono un ignorante totale ma non si potrebbe chiudere il diaframma di più? a 2.8 la pdc è pochina... poi magari per la macrofotografia si fa in un altro modo... nun zo, non ho mai fatto macro. Smile
nuvoletta
MessaggioInviato: Mer 13 Apr, 2005 11:32 am    Oggetto: Rispondi con citazione
Grazie del consiglio, ma ho provato usando una PDC maggiore, ma io nel mirino lo vedevo sempre nella stessa maniera......
aratrus
Iscritto: 12 Mgg 2004
MessaggioInviato: Mer 13 Apr, 2005 11:36 am    Oggetto: Rispondi con citazione
perchè il diaframma viene chiuso al momento dello scatto Wink
LE MIE FOTOGRAFIE|| 300D +18-55F3.5-5.6 ef-s + 50mm F1.8 II |
Antonio De Santis
Iscritto: 18 Ago 2004
MessaggioInviato: Mer 13 Apr, 2005 11:40 am    Oggetto: Rispondi con citazione
Prova ad utilizzare il pulsante per valutare la pdc, anche se chiudendo di molto vedresti molto scuro...
Hai utilizzato il cavalletto?
Perche' con quell'ingrandimento e a quella distanza potrebbe anche darsi che la messa a fuoco sia impossibile, passerai per punti di fuori fuoco senza trovare il punto di fuoco corretto!
E' questione di mm di spostamento della macchina...
Cmq il cavalletto qui e' d'obbligo.
Antonio
Daniele Carotenuto
Iscritto: 22 Dic 2003
esatto come dice aratrus... però esiste il tastino per l'anteprima della pdc.... cmq anche se lo vedi nel mirino così nello scatto ti uscirà con pdc maggiore... ad ogni modo con lenti simili e con le macro in genere si consiglia fuoco manuale, possibilmente fisso, e focheggiare spostando la macchina
nuvoletta
OK, Muro Muro Muro Muro proverò di nuovo..... ma come fare per avere un'idea di che cosa verrà poi nella foto?
Daniele Carotenuto
MessaggioInviato: Mer 13 Apr, 2005 11:42 am    Oggetto: Rispondi con citazione
sulla sinistra vicino all'obiettivo ci dovrebbe essere un tastino... che se premuto chiude il diaframma in anteprima
nuvoletta
MessaggioInviato: Mer 13 Apr, 2005 11:50 am    Oggetto: Rispondi con citazione
Il tastino lo conosco anch'io....e dai Mah ma mi sembra sempre uguale.... Boh?
Ieri ho provato come dici tu: cavalletto, fiore sul mobile, messa a fuoco manuale...e inserimento delle lenti per poi rifocheggiare sul soggetto.... notando tra le altre cose che le lenti macro con alcuni obiettivi hanno difficoltà per la messa a fuoco....
Spero che il 25 mi insegnerai qualcosa!!!! Very Happy
Daniele Carotenuto
MessaggioInviato: Mer 13 Apr, 2005 11:56 am    Oggetto: Rispondi con citazione
come fanno le lenti ad avere difficoltà di messa a fuoco? se lo metti in manuale???
cmq... ricapitoliamo... ad apertura massima il tastino non ti da effetti... ma se metti a F11 e premi il tastino non noti: A-diminuzione della luce che passa B-zona a fuoco + profonda?
blek
Iscritto: 05 Mar 2005
MessaggioInviato: Mer 13 Apr, 2005 11:57 am    Oggetto: Rispondi con citazione
A nuvole' sparo la mia - allontanati un po' dall'oggetto - forse sei ad una distanza dove non hai messa a fuoco come dice giustamente BLUEMOON
Antonio De Santis
MessaggioInviato: Mer 13 Apr, 2005 11:59 am    Oggetto: Rispondi con citazione
Si, ma anche stando ad una distanza superiore a quella minima di messa a fuoco, uno spostamento di anche un mm del corpo macchina-lente manda fuori fuoco il tutto, per questo dicevo che potresti anche non avere mai una messa a fuoco corretta.
Antonio
Daniele Carotenuto
MessaggioInviato: Mer 13 Apr, 2005 12:00 pm    Oggetto: Rispondi con citazione
e per questo motivo F2.8 è una follia... se si ha un F + alto si ha un margine d'errore un po' diverso Wink
nikomane
Iscritto: 31 Gen 2005
MessaggioInviato: Mer 13 Apr, 2005 12:26 pm    Oggetto: Rispondi con citazione
Vecchio adagio :
LE LENTI CLOSE UP VAN BENE SULLE COMPATTE, LE REFLEX AMANO GLI ANELLI DI PROLUNGA.
La mancanza di nitidezza è solo per questo motivo. Very Happy
www.aereofoto.it
Daniele Carotenuto
MessaggioInviato: Mer 13 Apr, 2005 12:29 pm    Oggetto: Rispondi con citazione
nikomane quelle lenti le ho usate io senza problemi di sorta... la mancanza di nitidezza si ha in condizioni estreme... e ad aperture elevate per i motivi di cui sopra...
se avessi qualche dubbio guarda qua
http://www.photo4u.it/viewtopic.php?t=19548&highlight=close
e si parla di F abbastanza bassi... alcuni scatti adirittura fatti con obiettivo non macro...
nuvoletta
MessaggioInviato: Gio 14 Apr, 2005 10:19 am    Oggetto: Rispondi con citazione
Mi spiego meglio: con le lenti macro e gli obiettivi Sigma ottengo un effetto velato, mentre con l'biettivo Canon ottengo l'effetto di ingrandimento e messa a fuoco....
Ho fatto varie prove e il risultato è sempre stato lo stesso....
Realizzato con Sigma 75-300 con lente +3
 Dimensione:  46.34 KB
 Visualizzato:  File visto o scaricato 615 volta(e)
Realizzato con Sigma 75-300 con lente +10
 Dimensione:  46.61 KB
Realizzato con Sigma 75-300 senza lente aggiuntiva
 Dimensione:  62.5 KB
nuvoletta
MessaggioInviato: Gio 14 Apr, 2005 10:28 am    Oggetto: Rispondi con citazione
questa foto invece è realizzato con la lente achomatic Sigma Apo e con l'obiettivo Sigma 75-300 mentre la successiva è realizzata con l'biettivo Canon e la lente macro +10 lultima è realizzata con il solo Sigma 105mm
 Dimensione:  63.15 KB
 Visualizzato:  File visto o scaricato 610 volta(e)
Canon EF S 18-55mm + Lente macro +10
 Dimensione:  56.91 KB
Sigma 105mm senza aggiunte
 Dimensione:  57.32 KB
Daniele Carotenuto
MessaggioInviato: Gio 14 Apr, 2005 10:38 am    Oggetto: Rispondi con citazione
nuvoletta è ancora il problema non è di messa a fuoco ma di F troppo bassi... Smile la +10 provata sul 50 a F1.8 da un effetto quasi soft focus..
nuvoletta
MessaggioInviato: Gio 14 Apr, 2005 11:01 am    Oggetto: Rispondi con citazione
Ok! OK, quindi il problema è solo trovare il giusto compromesso tra lente, obiettivo e diaframma......Doh! Doh! Doh! Muro Muro
farò pratica Ciao e Ave grazie mille
