photorepetto utente attivo
Iscritto: 05 Mgg 2004 Messaggi: 1018 Località: Zena
Inviato: Ven 10 Dic, 2004 10:07 am Oggetto: la D2000 ? |
Come mai hai optato per quella reliquia ?
Una gran bella macchina, la utilizzavo in quel, però ormai superata.
A quanto l'hai trovata ?
Lo sai che il CCD invecchia ....quindi controlla bene i pixell, perchè quelle macchine hanno lavorato molto ed il sensore a lungo andare perde di qualità.
Non ti voglio demoralizzare, ma solo avvertire di testarla bene.
Comunque sia complimenti ho dei bei ricordi con quel mula da lavoro..
Per chi non la conoscesse ecco la foto e le specifiche..in inglese..
Type AF single-reflex lens digital camera. Single-shot camera with 36 bit full-color (RGB each 12 bits). Object frame size: 15.5 x 22.8mm. 2 megapixel CCD (1,728 horizontal x 1,152 vertical pixels. Aspect ratio = 2:3, equivalent to 135 film) Maximum continuous shooting at 3.6 fps in 12-frame bursts.
Compatible Lenses Canon EF lenses (focal length increases by approx. 1.6 x)
Mount EF mount
AF system TTL cross type secondary image phase differential detection. Cross-type BASIS for AF sensor.
AF modes: One-Shot AF and predictive AI Servo AF, Manual.
af metering range: EV 1-19 (at ISO 200).
Shutter speed 1/8000 sec to 30 sec. B, X= 1/250 sec.
Viewfinder Full-frame single lens reflex type. Coverage of 97% vertically and 98% horizontally. 0.83x magnification. 20 mm eye relief. New Laser Matte screen is standard. Eight interchangeable focusing screens. Built-in dioptric adjustment.
Metering and
Exposure Control Evaluative metering with 12-zone SPC and TTL full-aperture metering using BASIS. Center- weighted averaging metering. Partial metering ( approx. 23.7%). Spot metering (approx. 9.1%). Fine spot metering (approx. 6.1%). Metering range (at ISO 200) : EV 1-19 with evaluative and partial metering. EV 2-19 with fine spot metering. Exposure compensation: ±3EV. ISO range: 200-1600. White balance: 5 types of preset including automatic or custom. E-TTL automatic flash exposure with a Canon EX series Speedlite.
Recording media PCMCIA-ATA Type I, II and III PC card
Data file format TIFF/EP (12 bit raw JPEG lossless compression)
Data file size Recording: approx. 2 MB. Capturing : approx. 6MB (8 bit acquiring) approx.
12 MB (12 bit acquiring)
Recording capacity: approx. 160 frames (Rough estimate when using 340 MB PC card)
Audio recording: recordable on given shot via built-in microphone.
Interface (1) IEEE1394 high-speed serial interface: exclusive cable which comes with the camera directly connected to IEEE1394 port..
(2)PC cards: accessed through a PC card reader using driver software. Driver software: Plug-in for Macintosh Adobe Photoshop and TWAIN driver for PC attached.
Built-in
color monitor Image data is displayed on 1.8" color LCD panel on the camera back. Shooting information and menu operation enabled on top and back B&W LCD panel.
Filter Built-in infrared-cut Low-Pass filter, removable by the user.
Power source Replaceable rechargeable Ni-Cd battery (up to 300 frames capacity when fully charged). AC adapter
Dimensions &
Weight 161 x 174 x 92 mm, 1650 g (without battery)
Descrizione: |
Dimensione: |
23.31 KB |
Visualizzato: |
File visto o scaricato 277 volta(e) |
_________________ Giuseppe Repetto
Editore SURFERS Mag. e GTClassic Car Mag. On-line ---> www.surfersmagazine.it - www.giusepperepetto.com - www.photorepetto.com - www.gtclassic.it - https://www.facebook.com/giuseppe.repetto
LIGURIA@Photo4U |
melarossa utente attivo
Iscritto: 09 Feb 2004 Messaggi: 9236 Località: Salento
