ernestino nuovo utente
Iscritto: 01 Feb 2007 Messaggi: 20
Inviato: Ven 09 Feb, 2007 10:20 am Oggetto: [Genova + ss] Canon EOS 1000 (analogica) 49 euro |
Vendo la fotocamera in oggetto, assolutamente come nuova senza un graffio. Solo corpo. Ottiche compatibili con le digitali. Ideale come secondo corpo in abbinamento alla digitale o anche per imparare.
Fornita senza imballo e con istruzioni su file.
Type 35mm focal-plane shutter multi-mode AF SLR camera
Picture Size 24x36 mm
Normal Lens EF 35-80mm f/4-5.6, others
Lens Mount EF mount
AF System TTL phase detection. AF modes: One-Shot AF/Predictive AI Servo AF (automatic switchover). AF operating range at ISO 100: EV 1 - 18.
Shutter Vertical-travel, focal-plane electronic shutter. 30 sec. - 1/2000 sec., B. X-sync at 1/90 sec. (hot shoe). Built-in electronic self-timer (with beeper and selectable melodies by Vivaldi, Beethoven and Bach).
Viewfinder Fixed eye-level pentaprism. 0.75x magnification and 90% coverage.
Viewfinder
Information AF mark, in-focus indicator, partial metering circle, depth-of-field AE, shutter speed, aperture setting, flash on/ready, soft-focus value, AE lock, exposure compensation, manual exposure level, and red-eye reduction lamp.
Metering &
Exposure Control Composite SPC for TTL full-aperture metering (3-zone evaluative or 9.5% partial at center) with shutter speed-priority AE, aperture-priority AE, Intelligent program AE, depth-of-field AE, 4 program AE modes, match-needle manual. Exposure compensation range of ±2 EV (in 1/2-stop increments). AE lock enabled. Metering range at ISO 100 and f/1.4: EV 2 - 20. Film speed range: ISO 6 to 6400.
External LCD Shutter speed, aperture setting, soft-focus value, film speed, film status indicator, manual exposure level, sound set No. and setting indicator, depth-of-field AE, battery check, and other indications.
Built-in Flash Located on pentaprism hump. Manually retractable head. TTL autoflash control (fires automatically in backlight and low-light conditions) with off-the-film metering. Red-eye reduction provided. Guide No. 14 (at ISO 100 in m).
Power Source One 6 V 2CR5 lithium battery
Film Loading &
Advance Align film leader at mark, then close the camera back for prewind loading. First, the entire roll is wound on the take-up spool. Then each time a picture is taken, the film advances back into the cartridge. Film transport with the built-in motor. Film advance speed: 1 fps.
Film Rewind After the last frame is exposed, the film is rewound automatically.
Dimensions &
Weight 148 x 100 x 69 mm, 470 g
16.11 KB |
File visto o scaricato 129 volta(e) |
Inviato: Lun 12 Feb, 2007 4:30 pm Oggetto: |
| up
