MANNA utente attivo
Iscritto: 23 Lug 2004 Messaggi: 5907 Località: Roma
Inviato: Mar 28 Ott, 2008 11:09 am Oggetto: ... |
MEMO PER ME...  _________________ | Canon 6D | Canon 5D MarkII | Canon 6D |
Canon 24/70 f4macroL | Canon 70/200 f/2.8 L | Canon 100/400 f4.5-5.6 | Extender Kenko 1.4x | 2 SPEEDLITE 580EX  |
webrunner utente attivo
Iscritto: 31 Mar 2005 Messaggi: 536
Inviato: Sab 15 Nov, 2008 11:45 am Oggetto: |
| Uscita la versione 2.4b2 |
ubald™ utente attivo
Inviato: Sab 15 Nov, 2008 1:30 pm Oggetto: |
grazie della info!
Bug fixes compared to beta1 are:
* multiple thumbnails for the same image bug fixed
* color propagation is back! However the luminance method is used instead in the file browser.
* proper rights for the "converted" folder under linux
* history panel cannot be resized after hide/restore fixed
* send to editor now does not freeze if the app path in invalid
* duplicate list of extensions in the preferences fixed (you have to delete your old options file!)
* tiff and rw2 extensions added to the default list of extensions
* color values under the mouse pointer are now correct
* directory browser now does not forget its width
* linear dng/canon sraw is now supported
* IPTC data in nef files is now detected/parsed
* several bugs fixed corresponding to the multiple selection in the file browser
Known issues (Several users have it but I can not reproduce them, please test it and post report to the forum if you found a reproducible scenario for these bugs):
* some people reported crash when save/save-as is pressed
* the preview zoom does not work properly (e.g. fit zoom)
* still no solution on the library dependency problems under older linux distributions _________________ il meno è più |
Inviato: Sab 15 Nov, 2008 1:31 pm Oggetto: |
| ubald™ ha scritto: | grazie della info!
* still no solution on the library dependency problems under older linux distributions |
per fortuna hanno corretto il bug dei nef... _________________ il meno è più |
goonico utente attivo
Iscritto: 01 Nov 2006 Messaggi: 1703 Località: Livorno--> Imola
ilmuto utente attivo
Iscritto: 11 Set 2007 Messaggi: 2054 Località: Bolzano
Inviato: Gio 18 Dic, 2008 11:35 pm Oggetto: |
Scaricato...
ma non riesco ad aprire i RAW della mia Panasonic FZ18...
Qualcuno mi può spiegare?  _________________
Mauro ------- PaP, VaV -------
I miei Contest: 58 - 45 - 44 - 43 - 40 - 39 - 38 - 35
Campo di concentramento di BUCHENWALD |
MisterG moderatore
Iscritto: 19 Dic 2003 Messaggi: 14013 Località: Monza
Inviato: Ven 27 Mar, 2009 11:27 pm Oggetto: |
ancora poco soddisfacente ma comunque usabile e con notevoli potenzialità, da tenere d'occhio  _________________
Inviato: Sab 28 Mar, 2009 10:29 am Oggetto: |
memo: siamo alla release candidate 2 _________________ il meno è più |
aspide78 utente attivo
Iscritto: 06 Set 2004 Messaggi: 575
Inviato: Mar 31 Mar, 2009 7:00 pm Oggetto: |
| oltre a essere buono è anche portable...ottimo direi... |
Matteo77 utente attivo
Iscritto: 08 Lug 2005 Messaggi: 2722 Località: Erba (Como)
ggc utente attivo
Iscritto: 10 Lug 2007 Messaggi: 518
Inviato: Mer 06 Gen, 2010 9:53 pm Oggetto: |
Raw Therapee 3 sarà licenziato sotto GPL ( cosa secondo me positiva in quanto ridurrà notevolmente il rischio di diventare non mantenuto o a pagamento ), e con tante novità previste a mio avviso interessanti...
http://www.rawtherapee.com/ |
Inviato: Gio 07 Gen, 2010 11:14 am Oggetto: |
Feature della 3 alfa:
| Citazione: | The most significant changes in the GUI are the following:
* multi-tab interface
* the real batch processing support arrived: select multiple images and adjust them together (the multi-adjust behavior of some parameters is selectable in the preferences dialog: they can be either additive or absolute)
* completely re-written editor: preview and detail view are now gone. The main image view can be magnified as required, and only the necessary part of the image will be re-calculated. There is a small navigator, too, and infinitely many detailed views can be opened to investigate fine details.
* 16 bit thumbnails (an option, takes double disk space)
* before/after view in the editor
The only change in the algorithms is:
* the behavior of the exposure controls changed. The "exposure" parameter is what was called "brightness" in previous versions. The "brightness" parameter is now a real brightness control, that shifts the histogram (of course with highlight/shadow protection)
Leggete le feature in arrivo:
| Citazione: | * new curve editor with parametric curve support
* per-image selectable demosaicing method + brand new demosaicing methods
* new color denoising method
* new luminance denoising method
* automatic C/A correction
* purple fringing correction
* perspective correction
* bad pixel removal
Ho sottolineato quelli che da punti deboli potrebbero diventare forti (denoise) e una funzionalità alla capture nx, la correzione automatica delle aberrazioni cromatiche!!!
Questo software è di qualità eccellente, trovo che per i bianconeri abbia pochi rivali. Con queste aggiunte poi... _________________ il meno è più |
Gabronski utente attivo
Iscritto: 18 Set 2008 Messaggi: 1299
Inviato: Sab 09 Gen, 2010 11:08 am Oggetto: |
anche la correzione della prospettiva è un'aggiuntina mica male  _________________ Nikon D600 + Sigma 150-500 f6.3 Nikkor 80-200 f2.8 + Nikkor 50 f1.8 + Nikkor 24-70 + Sigma 15mm f2.8 |
Inviato: Lun 11 Gen, 2010 10:15 am Oggetto: |
speriamo vada bene e fino in fondo, è un gran software, come dico da un po' _________________ il meno è più |
emmedi nuovo utente
Iscritto: 13 Ago 2007 Messaggi: 14
Inviato: Lun 19 Lug, 2010 11:25 am Oggetto: |
Sapete se esiste per rawtherapee qualcosa di equivalente ai preset per lightroom?
ciao |
paolov nuovo utente
Iscritto: 23 Ago 2010 Messaggi: 9
Inviato: Gio 14 Lug, 2011 2:59 pm Oggetto: |
Ciao a tutti,
ho cominciato anche io ad utilizzare il software in oggetto alla versione 3.0, ma non sono soddisfatto di come mi converte i colori dei miei raw (Nikon D80).
Ho visto che c'è la possibilità di usare un profilo .ICC in ingresso. Ho scaricato quello della D700 linkato dal sito del software e in effetti la resa è abbastanza simile al jpeg elaborato dalla fotocamera.
Mi sembra di aver letto che questi profili si possano scaricare dalla fotocamera attraverso il software CameraControlPro, che ovviamente non possiedo.
Voi come fate ad ottenere una resa cromatica simile al jpeg elaborato dalla macchina (giusto per avere un punto di partenza)?
Grazie,
Paolo. _________________ Nikon D80
http://www.flickr.com/photos/19freedom70/ |
